Sonarr version (exact version): 20180303-13
Mono version (if Sonarr is not running on Windows): 5.8.0.108
OS: Synology DSM 5.2.5297
Debug logs: Starting nzbdrone command env PATH=/usr/local/mono/bin:/volume1/@appstore/nzbdro
[Info] Bootstrap: Starting Sonarr - /volume1/@appstore/nzbdrone/share/NzbDrone/N
[Info] MigrationLogger: *** Migrating data source=/volume1/@appstore/nzbdrone/va
[Info] NancyBootstrapper: Starting Web Server
[Info] RssSyncService: Starting RSS Sync
[Info] DownloadDecisionMaker: Processing 500 releases
[Info] RssSyncService: RSS Sync Completed. Reports found: 500, Reports grabbed:
Description of issue: Ever since updating to 20180303-13, Sonarr never auto starts successfully and I always have to start it manually via Package Center. I’m running DSM 5.2 (not 6), so is there any fix I can apply to the auto start scripts?
