Sonarr version (exact version): 2.0.0.4689
Mono version (if Sonarr is not running on Windows): 5.8.0.108
OS: Synology DSM 6.1.5-15254 Update 1
Debug logs: Folder is not writable by user sc-nzbdrone
Description of issue: Cannot select path to shared folder that houses my content. I can choose the the top level of the shared folder but not any farther. I believe the permissions are set correctly. I’ve given permissions via Control Panel/Group/sc download & sc Media and checked read/write for download and video folder and for the application sonaar yet I am unable to select the path to video/tv shows. I tried creating new folders with the same result.
