I’ve got a drivepool drive “L:” running on Win10 where I intend to store all of my Sonarr related files, however I am getting some permissions issues. NzbGet downloads to a local drive “X:” and Sonarr is supposed to import those files to the local drivepool drive “L:”. I’ve already moved many files over to the Sonarr directory earlier and Sonarr has renamed them and moved them around, so I wouldn’t think permissions would be a problem. I already set “full access” to all users, admins, system etc… and it hasn’t fixed the issue.
I was getting another permissions based error on Sonarr for “C:\ProgramData\NzbDrone\bin”, but that error is gone after giving full permissions. Any ideas?
18-1-27 15:01:48.7|Warn|ImportApprovedEpisodes|Couldn't import episode X:\_NZBGet\intermediate\sonarr\XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-doosh-Obfuscated\61877b874a2a4b268b0932a611884627.mkv
[v2.0.0.5129] System.UnauthorizedAccessException: Access to the path 'L:\_TV\XXXXXXXXXXXXXX\Season 16' is denied.
at System.IO.Directory.InternalCreateDirectory(String fullPath, String path, Object dirSecurityObj, Boolean checkHost)
at System.IO.Directory.InternalCreateDirectoryHelper(String path, Boolean checkHost)
at System.IO.Directory.CreateDirectory(String path)
at NzbDrone.Common.Disk.DiskProviderBase.CreateFolder(String path) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Disk\DiskProviderBase.cs:line 180
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.CreateFolder(String directoryName) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:line 206
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.EnsureEpisodeFolder(EpisodeFile episodeFile, Series series, Int32 seasonNumber, String filePath) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:line 176
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.MoveEpisodeFile(EpisodeFile episodeFile, LocalEpisode localEpisode) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:line 77
at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeEpisodeFile(EpisodeFile episodeFile, LocalEpisode localEpisode, Boolean copyOnly) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:line 76
at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import(List`1 decisions, Boolean newDownload, DownloadClientItem downloadClientItem, ImportMode importMode) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:line 103
