Sonarr version (2.0.0.5228):
Mono version (5.12.0.301):
OS - Ubuntu 18.04 LTS:
Import failed, path does not exist or is not accessible by Sonarr: /home/Downloads/complete/Mindhunter.S01E03.1080p.WEBRip.x264-SERIOUSLY[rarbg]
Hi
I have set up Sonarr in a docker environment and paired it with Transmission. I have followed the guide in this link https://www.smarthomebeginner.com/docker-home-media-server-2018-basic/
My Sonarr Docker-Compose file is
sonarr:
image: "linuxserver/sonarr"
container_name: "sonarr"
volumes:
- ${USERDIR}/docker/sonarr:/config
- ${USERDIR}/Downloads/completed:/downloads
- ${USERDIR}/media/tvshows:/tv
- "/etc/localtime:/etc/localtime:ro"
- ${USERDIR}/docker/shared:/shared
ports:
- "8989:8989"
restart: always
environment:
- PUID=${PUID}
- PGID=${PGID}
- TZ=${TZ}
and my Transmission Docker-Compose file is
transmission-vpn:
container_name: transmission-vpn
image: haugene/transmission-openvpn
cap_add:
- NET_ADMIN
devices:
- /dev/net/tun
restart: always
ports:
- "9091:9091"
dns:
- 1.1.1.1
- 1.0.0.1
volumes:
- /etc/localtime:/etc/localtime:ro
- ${USERDIR}/docker/transmission-vpn:/data
- ${USERDIR}/Downloads:/data/watch
- ${USERDIR}/Downloads/completed:/data/completed
- ${USERDIR}/Downloads/incomplete:/data/incomplete
environment:
- OPENVPN_PROVIDER=NORDVPN
- OPENVPN_USERNAME=username
- OPENVPN_PASSWORD=xxxxxxxxx
# - OPENVPN_CONFIG="YYYYYYYYYYY"
- OPENVPN_OPTS=--inactive 3600 --ping 10 --ping-exit 60
- LOCAL_NETWORK=192.168.1.0/24
- PUID=${PUID}
- PGID=${PGID}
- TZ=${TZ}
- TRANSMISSION_RPC_AUTHENTICATION_REQUIRED=true
- TRANSMISSION_RPC_HOST_WHITELIST="127.0.0.1,192.168.1.0/24"
- TRANSMISSION_RPC_PASSWORD=admin
- TRANSMISSION_RPC_USERNAME=admin
- TRANSMISSION_UMASK=002
- TRANSMISSION_RATIO_LIMIT=1.00
- TRANSMISSION_RATIO_LIMIT_ENABLED=true
Sonarr can send torrents to Transmission, and Transmission can perform the download.
Once the torrent is finished the file moves to the {USERDIR}/Downloads/complete
Once it is in that folder, Sonarr is unable to pick it up and move it to the {USERDIR}/media/tvshows
In the logs it is throwing out the following errors
Import failed, path does not exist or is not accessible by Sonarr: /data/completed/Sonarr/
I have the volumes set as per the guide, and have run
sudo setfacl -Rdm g:docker:rwx ~/docker
sudo chmod -R 775 ~/docker
to give the appropriate permissions to the subsequently created files.
I have mounted a network folder inside my media/movies and media/tvshows folder. In nautilus they have a locked icon - and are controlled by root. I did try using “sudo setfacl -Rdm g:docker:rwx ~/media”, but it spat out setback: /home/USER/media/movies/Star Wars: Operation not supported. Also the “sudo chmod -R 775 ~/media” didn’t appear to do much either.
Any suggestions on how to get Sonarr to access the data/completed volume?
Some things that have me confused, is that the guide has Transmission thinking the files are downloaded to an internal mapping of data/completed, where as sonarr is looking for the files under an internal map of “downloads” - do these need to be the same.
