OzNZB indexer not found, as per Update 1014
I see the note on update .1014 says Oz has been added as a default indexer, but I don’t see it in the indexer tab. Am I blind?
Same here. I do though, have a “blank” entry (no name, URL, or API key) in the middle of my indexers list. I wondered if that was somehow caused by the failed addition of OZ. Though, I may have somehow created that myself in the past.
Anyway, I was able to add OZ as another Newznab provider but that doesn’t seem right based on the update notes. While the new addition seems have been accepted I do wonder 1) where the mentioned “default” entry is and 2) where my “blank” entry came from (as I can’t seem to create a blank entry now)?
Jeff
Sorry, wrote half a response and never finished.
Defaults are only included on new installs (at least right now) in retrospect I could/should have not added that to the change log.
You can always add as many newznab indexers are you like, I like to use 2-3 for best results and speed (more takes longer to process).
Regarding the blank one, must have been created before validation.
Okies. Not a big deal - I use nzbmegasearch to aggregate everything anywho.
But as Oz has ratings stuff via api, thought it would have some new features in Drone.
Wasn’t even aware of that, ratings for the episode or the release?
The release I believe. I am using the word ratings, but it may be something else. Current beta of Sab supports it.
I’ll have to investigate that further.
