Does Sonarr know to overwrite a Plex DVR recording? Or even know the difference. Ideally I would like to enable the Plex DVR but overwrite the fell if Sonarr finds a copy.
Sonarr won’t replace it if quality is the same (based on the filename/extension). Sonarr would need to know the file exists in order to delete it before adding it, otherwise there will be files left behind. It only find new files on disk during it’s 12 hour refresh.
