Since finding dubbed anime is tricky to do, since not all releases are even labeled as dubbed, would it be possible to add an option in Sonarr’s settings to add an Audio Language column to the Manual Search?
Sonarr uses the release title to determine what it contains, if thats not part of the title Sonarr won’t be able to report what the audio language is.
I thought this might just be an attribute that could be brought back from a search through an indexer.
Here’s the results in a Dognzb item.
If it’s not, then I understand.
I don’t see those on results in the API, must be something custom they do for showing on the site, which we don’t have access to.
