**Sonarr version (exact version): 2.0.0.5344
Mono version (Running in docker container on synology Nas): 5.20.1.34
OS: DSM 6.2.3-25426
Debug logs: https://drive.google.com/file/d/1sZXfQPRDW1eYgapYbPtS_BKJayNNS6nQ/view?usp=sharing
Adding a new series to sonarr ends in infinite loading circle and ends with error in the logs showing the “SkyHookProxy” timedout error
I do not have ssl turned on for Sonarr , i have radarr and sabnzbd working along side it and those two programs are working fine.
I am having the exact same issue - Can’t add new series and refreshing existing ones is hit and miss too…mine is running in a docker on Unraid
Just to let you know - I had to update to v3 and it sprang back to life.
Thank you so much~ I’ll definitely try that out…but I assume you’ll have to reconfigure Sonarr again?
