nzbGet & sonarr not working
Version
2.0.0.5163
Mono Version
5.10.1.47
OS: unRAID 6.5
Debug logs: https://pastebin.com/yU4wzAv1
I am having problems with Completed Download Handling with NZBGet, as you can see in debug log I cant access the files with sonarr… NZBGet chmod is set too 007.
Running unRAID with sonarr & nzbget docker, I need to fill out Remote Path Mapping and have the following setup:
192.168.1.xx:6789 \SKYNETS\TV Shows\Usenet\completed\tv / usenet/
I might have wrong remote path mapping as its new for me and I Have used drone factory up untill now.
My question is, what should my remote path mapping be and what other settings do I Need?
What does your docker config for these containers look like?
If your NZBget docker container and Sonarr both have the same internal path mapped to the same physical path then you don’t need a remote path mapping, but you’d need make sure permissions allow the Sonarr user to access it.
Read the help tooltip, that’s not the host, that host + port.
Wrong slashes for linux.
Thanks, the internal path worked just fine :slight_smile:
