manne
July 25, 2015, 6:14pm
1
Under settings > Download Client > I have added NZBGet
I can’t get: use SSL to work. I get "Unable to connect to NZBGet"
When I set Use SSL No, the test verification is okay.
Host: localhost
Port: 6789
(If I use sabnzbd, port 9090 and my API key it works, But I want NZBGet to use SSL too)
Sounds like SSL hasn’t been setup on nzbget.
manne
July 26, 2015, 6:32am
3
Thank you.
Anyone here who knows how to setup ssl on nzbget?
Under Security set SecureControl to Yes, and if desired change the SecurePort.
P.s. standard SSL port is 6791 (according to the installation manual I googled)
system
Closed
September 24, 2015, 12:27pm
6
