NZBGet and its Categories - Drone not finishing process
Hi,
I recently setup NZBGet last night, and I am having an issue with the Categories part. I set everything up like it was setup in SABnzbd, but NZBget is now extracting to and putting my downloads in a sub folder (TV_HD) in my completed folder. Drone will not find the downloads now thus will not automatically finish the process of renaming and moving the file its correct folder. I wish to keep my “watched” folder for Drone as is. I have different qualities for different shows thus would need Drone to monitor multiple folders instead just my main one.
I have deleted all my categories in NZBget, but it still does it. Any ideas on how to shut this off, or have Drone look into the sub folders it creates?
Thanks,
NuTZ
LOL… after i posted this, i found the option to disable the new dir. sometimes thats all it takes to find what you are looking for…
thanks,
NuTZ
