So I did a ‘service nzbdrone restart’ (running Ubuntu 14.04) of nzbdrone while making some configuration changes, nzbdrone restarted, the process was running, but I noticed that nothing was listening on the bound port.
I checked the log file and found the following repeating:
nzbdrone start/running, process 16756
14-7-23 15:49:27.0|Info|Bootstrap|Starting NzbDrone - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.1632
14-7-23 15:49:28.0|Info|MigrationLogger|*** Migrating data source=/home/media/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal ***
14-7-23 15:49:28.2|Info|MigrationLogger|*** Migrating data source=/home/media/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal ***
14-7-23 15:49:28.3|Info|Router|Application mode: Interactive
14-7-23 15:49:28.3|Info|OwinHostController|Listening on the following URLs:
14-7-23 15:49:28.3|Info|OwinHostController| http://*:8989//
14-7-23 15:49:28.5|Info|NancyBootstrapper|Starting NzbDrone API
14-7-23 15:49:32.1|Info|HousekeepingService|Running housecleaning tasks
14-7-23 15:49:32.2|Info|DownloadDecisionMaker|Processing 3 reports
14-7-23 15:49:33.2|Info|MissingEpisodeSearchService|Episode search completed. 0 reports downloaded.
14-7-23 15:49:33.4|Fatal|ConsoleApp|EPIC FAIL!
NzbDrone.Host.Owin.PortInUseException: Port 8989 is already in use, please ensure NzbDrone is not already running. ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Net.HttpListenerException: Prefix already in use.
at System.Net.EndPointListener.AddSpecial (System.Collections.ArrayList coll, System.Net.ListenerPrefix prefix) [0x00000] in <filename unknown>:0
at System.Net.EndPointListener.AddPrefix (System.Net.ListenerPrefix prefix, System.Net.HttpListener listener) [0x00000] in <filename unknown>:0
at System.Net.EndPointManager.AddPrefixInternal (System.String p, System.Net.HttpListener listener) [0x00000] in <filename unknown>:0
at System.Net.EndPointManager.AddListener (System.Net.HttpListener listener) [0x00000] in <filename unknown>:0
at System.Reflection.MonoMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00000] in <filename unknown>:0
at System.Reflection.MethodBase.Invoke (System.Object obj, System.Object[] parameters) [0x00000] in <filename unknown>:0
at Microsoft.Owin.Hosting.ServerFactory.ServerFactoryAdapter.Create (IAppBuilder builder) [0x00000] in <filename unknown>:0
at Microsoft.Owin.Hosting.Engine.HostingEngine.StartServer (Microsoft.Owin.Hosting.Engine.StartContext context) [0x00000] in <filename unknown>:0
at Microsoft.Owin.Hosting.Engine.HostingEngine.Start (Microsoft.Owin.Hosting.Engine.StartContext context) [0x00000] in <filename unknown>:0
at Microsoft.Owin.Hosting.WebApp.StartImplementation (IServiceProvider services, Microsoft.Owin.Hosting.StartOptions options, System.Action`1 startup) [0x00000] in <filename unknown>:0
at Microsoft.Owin.Hosting.WebApp.Start (IServiceProvider services, Microsoft.Owin.Hosting.StartOptions options, System.Action`1 startup) [0x00000] in <filename unknown>:0
at NzbDrone.Host.Owin.OwinHostController.StartServer () [0x00000] in <filename unknown>:0
at NzbDrone.Host.NzbDroneServiceFactory.Start () [0x00000] in <filename unknown>:0
at NzbDrone.Host.Router.Route (ApplicationModes applicationModes) [0x00000] in <filename unknown>:0
at NzbDrone.Host.Bootstrap.Start (ApplicationModes applicationModes, NzbDrone.Common.EnvironmentInfo.StartupContext startupContext) [0x00000] in <filename unknown>:0
at NzbDrone.Host.Bootstrap.Start (NzbDrone.Common.EnvironmentInfo.StartupContext startupContext, IUserAlert userAlert, System.Action`1 startCallback) [0x00000] in <filename unknown>:0
at NzbDrone.Console.ConsoleApp.Main (System.String[] args) [0x00000] in <filename unknown>:0
I use the templated init script found in the wiki:
author "Simon Tallmyr - Nosscire"
description "Upstart Script to run NzbDrone as a service on Ubuntu/Debian based systems, as well as others"
#Set username for the process. Should probably be what you use for logging in
setuid media
#This is the install directory. If you installed using a deb package or the NzbDrone Repository you do not need to change this
env DIR=/opt/NzbDrone
setgid nogroup
start on runlevel [2345]
stop on runlevel [016]
respawn
exec mono $DIR/NzbDrone.exe
I can also confirm that NOTHING is listening or bound to port 8989 on any interface on the server, as evidenced by a netstat -ntpl.
Now what’s really weird, is if I try to manually execute it as a user that’s NOT the ‘media’ user (any other user, root or another non-privileged user for example) I have this set up to run as, it starts up just fine without any issue what so ever.
I noticed the following in the logs (I was attempting to get this set up for reverse proxy and suspect that’s the damage):
Unfortunately I’ve found no way to manually edit any configuration anywhere that would let me correct what I can only assume is causing the issue here and the reverse proxy is somehow trying to bind a separate instance to the same port.
I’ve even attempted to do a select * from each of the tables in the nzbdrone.db sqlite database and not managed to find anywhere in there where the proxy setting is toggled.
At this point I can only assume that this setting is in one of the mdb access database files and the mdb-tools suite doesn’t seem to be capable of doing anything with those.
Have I pretty much found myself backed into a corner whereby my only option is to fully set nzbdrone back up again? I’m really hoping not
