Nzbdrone Processing issues
Nzbdrone sent the download to sabnzbd but cannot pick it up and process it from the downloads folder.
celebrity.big.brother.uk.s13e01b.bit.on.the.side.pdtv.x264-w4f.mp4
http://thetvdb.com/?tab=series&id=70760&lid=7
This is covered on the wiki in our FAQ: https://github.com/NzbDrone/NzbDrone/wiki/FAQ#why-cant-nzbdrone-import-episode-files-for-series-x--why-cant-nzbdrone-find-releases-for-series-x
Ok so i submitted.
Why would it download though and not process it?
Downloading can fall back to tvrage id matching when the title doesn’t match, if the feed supplies it, but since thats not available on import the import relies wholly on the name.
I have added it, drone will auto update the list every 6 hours, once added it should import successfully.
Perfect thank you!
Hopefully it is ok to revive this topic. Does the following fall into this situation:
The Real World
http://thetvdb.com/?tab=series&id=76522&lid=7
Has an aftershow and when the real world is searched with nzbdrone it picks it up by accident sometimes. I am not bothered about the aftershow and it isn’t even on the tvdb. But i’d like to stop nzb picking it up instead of the main show.
Or do we have an option to ignore keywords?
They’re named like the real show so you will need to use release restrictions to block “aftershow”, its an advanced option on the indexer settings page.
I guess i need to learn to scroll down more often.
