I’ve googled around and found no answer to the problem I am having.
I am running sabNZBd with NZBDrone on a Ubuntu 12.04 server.
sab downloads my tv shows to a /media/storage/complete/tv, and that is the drone folder for NZBDrone.
The problem is NZBDrone is grabbing the files from that folder before sab can finish unpacking the file. So instead of a 4GB file, I get a file anywhere from 150MB to 1GB.
I do have the switch enabled in sab which inserts a “UNPACK” to the folder name, and my understanding is NZBDrone is supposed to ignore those folders if they haven’t been written to in 5 minutes. Except that is not happening and it rips the file out of there before it is finished.
NZBDrone Version: 2.0.0.1269
SabNZBd Version: 0.7.17
My current solution is to change the scan drone folder option to 15 minutes, which is a little crazy. I should note that this issue only recently popped up, and didn’t happen before.
