Nzbdrone in a loop (hanging)
After filling in the api key for sabnzbd, nzbdrone gave the sesponse: Internal Server Error : /api/queue. So i tried to go to ‘Settings’, but nzbdrone got in a loop. The same message is constantly appearing, but the settings don’t show. Is there a solution?
Drone begins checking the SAB queue almost immediately (its how failed downloading is handled), but settings should still load even if SAB settings are invalid. If settings will not load at all, then something has been saved that is is preventing drone from re-reloading them.
If you haven’t added any shows then the quickest solution is to delete nzbdrone.db from the AppData location (Viewable on System -> Info) by default on Windows its in C:\ProgramData\zbDrone (ProgramData not Program Files).
Otherwise you could go into the SQLite DB and clear the config table to remove all the settings and start again.
Markus, thanks for your answer. It was very helpfull. I’ve deleted the nzbdrone.db and settings are accessable again.
Thought mine was hanging this morning also…turns out NOSCRIPT was blocking the page. Just posting in case anyone overlooks this down the road.
