Sonarr version (exact version): 2.0.0.5129
OS: Windows 10 Build 16299
Debug logs: https://goo.gl/zJ1myx
The NzbDrone.exe task is at a constant 15% or so CPU usage. It isn’t crippling, but I’m curious as to what it’s busy doing and if there’s any way it can be alleviated.
It appears to be stuck doing a ‘RefreshSeries’ command b/c the trace log always shows that one is currently in progress. I believe this has been addressed in previous versions so i’m not sure if this is a regression defect or if I haven’t configured something correctly. Any ideas?
