I currently have 7 Newznab indexers set up, and for some reason both nzbgeek indexes do not work with nzbdrone. I at first thought the API key may have been wrong, but it works without problems in sickbeard. Below are the logs.
I replaced my APIKey with *'s
13-5-21 18:26:10.8|Core.Providers.Indexer.Newznab|Error|An error occurred while processing feed. https://vig.nzbgeek.info/api?t=tvsearch&cat=5030,5040,5070,5090&apikey=********************************&limit=100&q=Mad%20Men&season=3&ep=4|System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a send. ---> System.IO.IOException: Received an unexpected EOF or 0 bytes from the transport stream. at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.TlsStream.CallProcessAuthentication(Object state) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Net.TlsStream.ProcessAuthentication(LazyAsyncResult result) at System.Net.TlsStream.Write(Byte[] buffer, Int32 offset, Int32 size) at System.Net.PooledStream.Write(Byte[] buffer, Int32 offset, Int32 size) at System.Net.ConnectStream.WriteHeaders(Boolean async) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.GetResponse() at NzbDrone.Common.HttpProvider.DownloadStream(String url, NetworkCredential credential) in c:\\Source\zbDrone.Common\\HttpProvider.cs:line 58 at NzbDrone.Core.Providers.Indexer.IndexerBase.Fetch(IEnumerable1 urls) in c:\\Source\zbDrone.Core\\Providers\\Indexer\\IndexerBase.cs:line 187
Thanks for any help regarding this issue, and thanks so much for this alternative to sickbeard. So far it’s great and I could never go back to sickbeard, even with these two indexers not working
