It would be nice if I do a automatic search and it docent find the show to give me a notification that it didn’t find the show and also in the history I would like to see from which Indexers was the show downloaded.
There a UI notification showing that no results were added to the queue.
You can see the indexer, check the details of the history item.
Thank you Markus you are fast replaying.
I did find the indexer information but I don’t see the UI notification.
For example I go to calendar, there I find I have a missing show, then I do a automatic search of the show and it only give me 2 notification the first one is "[episodesearch] Searching 4 indexers for [Tut : SO01E03] and the second one is "[episodesearch] Completed. So I don’t see another notification with “no results were added to the queue”.
I am using the latest Google Chrome.
There is definitely a UI message that says it didn’t find anything, but may be getting hidden by the completed message. We’ll have to take a look. Another indication is the missing icon doesn’t change, when something is grabbed it will change to a cloud then a progress bar, not a perfect solution, but you won’t be completely in the dark.
