Not snatching Schitts Creek from BTN
Sonarr lets me add Schitts Creek but it cannot see the releases on BTN…
They are there as i have downloaded them manually…
I wondered if it’s something to do with the apostrophe in the name (Schitt’s) ?
The apostrophe will get removed when searching and matching the title, so it shouldn’t cause any issues.
It came through usenet okay, does BTN have the apostrophe in the title?
Hi, BTN does have the apostrophe yes… if i search for it without, it does not bring up any results.
We’ll have to take a look at this, might be related to a lack of a tvrage ID, so might end up being fixed by properly adding it (on our side), I’ll take a look.
Many thanks :slight_smile:
I believe this issue is due to a missing TVRage ID on BTN’s side. The search is using the TVRage ID correctly.
