Not finding HD-raw files
Version 2.0.0.4645
Mono Version 3.10.0
FreeNAS 9.10 U2
When searching manually for an episode that exists on my nzb provider it doesn’t find the episode. I deleted my logs and then searched for the episode. The sonarr.log shows:
17-3-14 10:30:21.6|Info|NzbSearchService|Searching 1 indexers for [********** : S05E10]
17-3-14 10:30:26.0|Info|DownloadDecisionMaker|No results found
Debug log
I have HD-raw in my any profile and that is the profile for this show.
Your indexer didn’t return any results, either because it’s in a category other than 5030 or 5040 or the indexer failed to return the results.
I didn’t realize that the category setting affected what the indexer gave as a result.I’ve added other categories for TV 5000,5020,5030,5040,5050,5060. Are there any others that are an option? Not sure where to find a list of them. Is that the typical setting? Thanks.
5000 should include all categories in 5030, 5040, etc.
The indexer will have them listed, though you need to look at the URL for each category to pull it out.
