Not enough seeders?
I’ve done some manual searches on some shows that aren’t downloading and found that Sonarr has three or four torrents listed, but all show 0/0 seeders. However, this is not correct. For example, last night’s Penn and Teller on KAT had 19 seeders when I forced it to download and had been out for 6 hours. Last nights Late Show had over 250 seeders, but Sonarr showed 0/0, The Mindy Project, 183 seeders, but 0/0 for Sonarr (that one was only 80 minutes old though).
This has started in the last two weeks (since the fall season has started).
I don’t know if this is related, but a few of nzbs are also failing with a “out of your server’s retention” errors, but if I grab the same show manually on binsearch, it downloads fine.
I am using KickassTorrents, Nyaa, Usenet Crawler, and Wobbles as indexers.
KAT doesn’t properly show peers/seeders for about 14 hours on RSS/search, but they do on their site, we’re implementing a work around, but ultimately its broken on their end (they are aware as far as I know).
Sounds like a propagation issue, setting a minimum age for NZBs would help if its propagation.
+1 to the issue with KAT almost always rejecting releases for not enough seeders. Any sort of workaround, even being able to disable the seeder check for KAT would be awesome, thanks!
