Sonarr version (exact version): 2.0.0.4949
OS: Windows 10 Pro
((Debug logs)): https://1drv.ms/t/s!AlL0Y30lZHlTueEpWBReDM3j7t8BNQ
I have an anime series called “.hack” which sits in a folder called “dotHack (2003)”. The files inside are organised by season (i.e. /Season 01/). No media files are found on a disk scan, despite them all existing and being named correctly. An example file with full path would be “P:\Videos\アニメのテレビ\dotHack (2003)\Season 01.hack - S01E01 (#001) {HDTV-720p}.mkv”. All other series under “P:\Videos\アニメのテレビ” work fine. These episodes used to be detected fine (and were detected and named by Sonar).
I imagine the problem is that files starting with a dot are being ignored after an update.
How can I get the episodes to be detected?
