Sonarr version (exact version): 3.0.6.1196
OS: TrueNAS
Debug logs: System.ComponentModel.Win32Exception (0x80004005): ApplicationName=‘mono’, CommandLine=’–debug /tmp/sonarr_update/Sonarr.Update.exe 37079 /tmp/sonarr_update /usr/local/share/sonarr/Sonarr.exe /data=/usr/local/sonarr /nobrowser’, CurrentDirectory=’’, Native error= Cannot find the specified file
Description of issue: not sure if this topic was covered been struggling for a while find the same discussions but not able to fix my issue tried all the other solutions but still get the same issue NzbDrone path doesn’t exist under the jail I have any help would be appreciated but it should be the same issue for sonarr and radarr because both is giving the same issue, when I run ln -s /usr/local/bin/mono /usr/bin/mono it just says ‘Read-only file system’
The sonarr team does not maintain the truenas bsd plugins
you likely will have better luck on the forums https://www.truenas.com/community/forums/apps-plugins/
for radarr, the mono version is end of life and should not be used https://radarr.video/#downloads-v3-bsd
