Not able to import an existing serie
Hello, I’ve manually dl the TV serie Jeeves and Wooster.
When trying to add it through the add serie -> Import existing Sonarr creates the serie but doesn’t recognize the exiting files.
Here the logs:
http://pastebin.com/s8LkB6c4
From it I can see it is parsing the files but it seems no command is given to add them to the serie
I’ve tried changing folders names or files names to include the serie title but the results are the same.
The serie setting has the “any” profile.
Any idea how to solve this?
Thank you
It looks like the issue may be the naming, are all your series named that way?
1.04 - How Does Gussie Woo Madeline.mkv
Its getting parsed as anime treating the 1 as the title the . as a separator and 04 as absolute episode 4.
Try renaming the files to 1x04 or S01E04 style naming.
That was it!
Thank you very much!
