Noob connectivity : Unable to connect to indexer: Error: ConnectFailure (Connection refused)
Sonarr version (exact version): 2.0.0.4472
Mono version (if Sonarr is not running on Windows): 4.9.0 (master/aacea00 Fri Feb 3 08:03:56 EST 2017)
OS: OSX 10.10
((Debug logs)):
System.Net.WebException: Error: ConnectFailure (Connection refused) —> System.Net.Sockets.SocketException: Connection refused
at System.Net.Sockets.Socket.Connect (System.Net.EndPoint remoteEP) [0x000b0] in /private/tmp/source-mono-master/bockbuild-xamarin/profiles/mono-mac-xamarin/build-root/mono-x86/mcs/class/System/System.Net.Sockets/Socket.cs:879
at System.Net.WebConnection.Connect (System.Net.HttpWebRequest request) [0x0016d] in /private/tmp/source-mono-master/bockbuild-xamarin/profiles/mono-mac-xamarin/build-root/mono-x86/mcs/class/System/System.Net/WebConnection.cs:194
at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00059] in /private/tmp/source-mono-master/bockbuild-xamarin/profiles/mono-mac-xamarin/build-root/mono-x86/mcs/class/System/System.Net/HttpWebRequest.cs:1031
at System.Net.HttpWebRequest.GetResponse () [0x0000e] in /private/tmp/source-mono-master/bockbuild-xamarin/profiles/mono-mac-xamarin/build-root/mono-x86/mcs/class/System/System.Net/HttpWebRequest.cs:1043
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x00130] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:74
at NzbDrone.Common.Http.Dispatchers.FallbackHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x000cc] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\Dispatchers\FallbackHttpDispatcher.cs:58
at NzbDrone.Common.Http.HttpClient.Execute (NzbDrone.Common.Http.HttpRequest request) [0x0007e] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\HttpClient.cs:63
at NzbDrone.Core.Indexers.HttpIndexerBase1[TSettings].FetchIndexerResponse (NzbDrone.Core.Indexers.IndexerRequest request) [0x0004b] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:297 at NzbDrone.Core.Indexers.HttpIndexerBase1[TSettings].FetchPage (NzbDrone.Core.Indexers.IndexerRequest request, NzbDrone.Core.Indexers.IParseIndexerResponse parser) [0x00000] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:283
at NzbDrone.Core.Indexers.HttpIndexerBase`1[TSettings].TestConnection () [0x0000e] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:311
Hi, I’m at my wits end, it was working perfectly up until a few days ago now. No OS updates, no change in configuration to my system during this time period, simply stopped working for all RSS feeds.
Above is the output for the attempt to connect to Wombles. If I try to use an RSS feed I receive a ‘Indexer feed is not supported: Could not parse feed from …’ with the following log output…
I’ve tried two versions of Mono, the 4.3. … and the current latest 4.9… (mentioned above). Any ideas? And apologies as this really is a noob thing but I’ve gone through teh installation countless times with the same result.
The other slight confusion is the reference to M:\…
Please post debug logs elsewhere as requested (and more than just the snippet) next time.
Womble’s is no longer functional: https://www.reddit.com/r/usenet/comments/5l6soy/farewell_wombles_nzb_index/
That’s where Sonarr was built (on our build server), important information to us, but the full path doesn’t mean anything.
Hi, thanks for getting back so fast. Didn’t know about wombles demise as I was using the setup docs which mentions it.
The log file can be found here
