Sonarr version (exact version): 2.0.0.4753 Mono version (if Sonarr is not running on Windows): Mono JIT compiler version 5.0.1.1 OS: Ubuntu 14.04.3 LTS Debug logs:
While using Jackett to search a private indexer for torrent releases, the Sonarr search fails and displays “No results found” in the UI, even though the trace says a release was found and accepted. This search and others work fine from the Jackett interface. I have other usenet and torrent resources configured and those spout out results amazingly well, but if I enable this particular torznab resource, every search fails. I’m having a hard time reading the log and understanding the “System.ArgumentException: The string can’t be left empty, null or consist of only whitespaces. Parameter name: key” line and the ones that follow in the Sonarr log.
Each release has a unique identifier, this identifier is missing from the releases reported by Jackett so regardless that Sonarr sees something, it cannot process them.
You can see an example of the guid I’m talking about here.
