No Matching Series on post-processing
Hi there,
I am having issues during the post-processing of my new setup.
I am running NZBGet and NZBDrone on Windows with Python 2.7 and Pywin.
NZBDrone sends the series to be downloaded to NZBGet and it is downloaded successfully but in the post-processing script, Drone doesn’t understand the series name as it removes all the spaces in the title:
14-7-21 10:41:02.0|Debug|ParsingService|No matching series thegreatbritishsewingbee
The serie is The Great British Sewing Bee.
The downloaded serie is in the following format, nothing unusual:
The.Great.British.Sewing.Bee.S01E01.HDTV.x264-FTP
Any idea how I can get the ParsingService to include the “dots” ?
Cheers
drone always removes spaces and special characters then converts everything to lowercase when looking for series in your library.
The issue is a series with that title can’t be found (the official series title doesn’t contain “The”), which is covered in the FAQ: https://github.com/NzbDrone/NzbDrone/wiki/FAQ#why-cant-nzbdrone-import-episode-files-for-series-x--why-cant-nzbdrone-find-releases-for-series-x
Thanks for your reply, I will check this now and see how I can workaround this.
Cheers
Apparently the official title has the “the” in the title, according to the BBC.co.uk website (http://www.bbc.co.uk/programmes/b03myqj2)
The problem seem to be that Drone is mistakenly naming the serie with the “the”, how can I force Drone to add the The to match the real name of the serie?
Since the official title has “the” in the title then TVDB needs to fix the name, which will require a request to them, lily on their forums.
Once its fixd on TVDB trakt will pull it in and drone will update as well.
Thank you, I will try to get TVDB to change their record.
