When on on my Mac and I view my calendar, all is working fine. However, if I view my calendar using my iPad, I don’t see the legend that shows the colors for the status of each show, and none of the shows are color coded the way they are on the desktop. They are all blue.
Can I fix that?
Also, is there any way to set up iDevice usage so that I can save my user name and password? Presently, I need to enter my credentials every time I want to go use Sonarr…
