Sonarr version (exact version)****: 2.0.0.5343
OS: Windows 10
Debug logs:**
20-8-2 15:06:36.1|Warn|Newznab|Unable to connect to indexer
[v2.0.0.5343] System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:1080
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
at System.Net.HttpWebRequest.GetResponse()
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse(HttpRequest request, CookieContainer cookies) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:line 117
at NzbDrone.Common.Http.Dispatchers.FallbackHttpDispatcher.GetResponse(HttpRequest request, CookieContainer cookies) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Http\Dispatchers\FallbackHttpDispatcher.cs:line 53
at NzbDrone.Common.Http.HttpClient.ExecuteRequest(HttpRequest request, CookieContainer cookieContainer) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Http\HttpClient.cs:line 121
at NzbDrone.Common.Http.HttpClient.Execute(HttpRequest request) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Http\HttpClient.cs:line 57
at NzbDrone.Common.Http.HttpClient.Get(HttpRequest request) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Http\HttpClient.cs:line 264
at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider.FetchCapabilities(NewznabSettings indexerSettings) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:line 62
at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider.<>c__DisplayClass4_0.<GetCapabilities>b__0() in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:line 35
at NzbDrone.Common.Cache.Cached`1.Get(String key, Func`1 function, Nullable`1 lifeTime) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Cache\Cached.cs:line 81
at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider.GetCapabilities(NewznabSettings indexerSettings) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:line 35
at NzbDrone.Core.Indexers.Newznab.Newznab.get_PageSize() in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Indexers\Newznab\Newznab.cs:line 23
at NzbDrone.Core.Indexers.Newznab.Newznab.GetRequestGenerator() in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Indexers\Newznab\Newznab.cs:line 27
at NzbDrone.Core.Indexers.HttpIndexerBase`1.TestConnection() in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 334
20-8-2 15:06:36.1|Warn|NzbDroneErrorPipeline|Invalid request Validation failed:
-- Unable to connect to indexer, check the log for more details
About a month or two ago, NZB Geek just stopped working. When I test the indexer from within Sonarr settings, I get: Unable to connect to indexer, check the log for more details. Log is posted above. The issue seems to be: “No connection could be made because the target machine actively refused it 127.0.0.1:1080”
I’m not sure where to go from here. I’ve turned off my VPN. Disabled all firewalls possible. Checked TLS settings. Even used netstat command to see if anything else is running on that port and nothing.
Any guidance or help is greatly appreciated!
