Sonarr Version 3.0.6.1265 ( in docker)
Synology DSM 7
root. folders are missing.
not sure how to fix the issue.
Synology DSM 7
Any chance you’re the same guy who posted on reddit in both sonarr and radarr?
yes I am, I got the tv shows folders working, its just new downloaded episodes will not move from the downloads folder in to the proper tv show folder.
same comments on reddit for here
https://wiki.servarr.com/sonarr/troubleshooting#downloads-and-importing
I checked all my paths all match up with each other for the downloads folder.
all my permissions are all good for the folders
all the root folders are good also
all download clients all point to the same folders.
So you got some trace logs and screenshots from the troubleshooting to share then?
