Need help with restrictions
2.0.0.4753
Win 10 Pro
https://pastebin.com/9vpQvA8D
Hi all :slight_smile:
I am having problems with the restrictions. Sonarr keeps downloading shows from release group TBS.
I added TBS to must not contain. I set tags for the show, but sonarr is downloading their releases.
It should reject TBS, right?
And sonarr starts to download the TBS release.
I’m doing something wrong I guess, but I can not figure out what I’m doing wrong.
Tag preacher, must not contain TBS, must contain dd5.1. It is downloading the bloody 2 channel AAC TBS releases.
Any help would be appreciated, thx in advance.
Regards
Did you add the preacher tag to the series Preacher? The same tag must exist on the series for the restriction to apply (it doesn’t match via series title).
No. I did not. I knew I’m doing something wrong. Thanks for your help. :grin:
