Sonarr version (exact version): 3.0.6.1265
OS: FreeBSD 12.2
Debug logs: sonarr.debug.txt sonarr.txt
i use Sonnar primary for download anime and then view the show in PMS , and normally i don’t use the rename settings, with the ‘Name of the show/Season x’ its enough, but with a few series its needed to rename the episodes (the few that use absolute number), so i made a custom script to activate ‘on import’ and ‘on upgrade’ and worked flawlessly on v2, but its not working on v3. ithis is the script:
#!/bin/sh
myheader="@/path/to/header.txt"
myenable="@/path/to/enable.json"
mydisable="@/path/to/disable.json"
myCommand="{\"name\":\"RenameFiles\",\"seriesId\":$sonarr_series_id,\"files\":[$sonarr_episodefile_id]}"
echo "Enable Rename"
curl -X PUT -H $myheader --data $myenable "http://sonarrip:8989/api/v3/config/naming"
sleep 5
echo "Renaming..."
curl -X POST -H $myheader --data $myCommand "http://sonarrip:8989/api/v3/command"
sleep 5
echo "Disable Rename"
curl -X PUT -H $myheader --data $mydisable "http://sonarrip/api/v3/config/naming"
echo "Done"
it’s basically:
enable rename settings
rename the episode
disable rename settings
it’s looks like it rename it at the script, when the rename setting are disabled
Thanks
*English it’s not my native language
