Sonarr version (3.0.3.830):
Mono version (3.0.3.830):
OS: docker on Synology NAS
Description of issue: sonarr don’t see the new episode of the show
Hello,
I don’t understand how to configure Sonarr. I solved the problem with Radarr to use dronefactory.
But how can i do with radarr ?
I have a distant Seedbox (seedbox.io): so i can’t do a remote path mapping.
The NAS download automaticaly the TV Show in a folder (eg : download).
I want’t sonarr detects automatically this shows, and then rename / move (or copy) the file to the right folder.
Isnt it possible ?
I have a folder /data, with subfolder download and tvshow (where i have all the show correctly named)
/data
/data/download
/date/tvshow
Thank you for your help.
NB: with radarr i use the fonctionnality “dronefactory” , who scan a folder to detect if something new exists in the folder, and then rename and move to the right place.
