I just got a Mac and need help setting up Sonarr I want to use transmissions, and Plex …please help me!!!
Why can other people get replies but no one can help me out with this??
Because you’ve provided zero helpful information to go on, didn’t follow the template that was provided for you to submit this, and haven’t explained what you’ve already tried/consulted.
When you go into sonarr to link transmission I do t know what to put in the fields to link them together. To use transmission to download sonarr tv shows
This is really just asking people to do your entire setup, something which most techies frown upon…
Anyway. Hover over the (?) icon next to each field, you should get a good start from that. If anything specific confuses you, please provide more information or ask more detailed questions. E.g. “I don’t understand what to put in field xx, where can I find that information in transmission?”, "I have tried with these settings, and I’m getting this error in the debug logs. I don’t understand the error, can someone explain?"
Also give some more information about your general setup.
What people here will assume: transmission is installed and working (manually adding torrents and downloading is ok). If not, please check the official transmission site and see how to get support for that application. Same goes for plex you mentioned in your first post.
One of the main things is I can’t find the properties folder on transmission. Guess I could have just said that. So are asks for user name and password not for radar but where you go to enter the Downloader not sure what to put in there.
Welcome to the world of the Mac,
Not everyone has a Mac so the amount people that are able to help you isn’t that much compared to other OS’s
I don’t use transmission,
but you could check what the default user/pass are for transmission to use,
or else change it to something you can remember yourself to use.
The Directory option in Sonarr is optional.
All explained when you press the question mark.
When asking help give as much information as possible or add screenshots with the parts you don’t understand.
