ND won't add an episode of Battlestar Galactica
I am trying to add this series episode but ND comes up with the error below. Battlestar.Galactica.MiniSeries.Part1.720p.HDDVD.DTS.x264-CtrlH
[POST] Internal Server Error : /api/release
I sent you a PM Markus.
Thanks in advance.
Shedrock
And the release says Unknown Series next to it… which is why it doesn’t work.
Pretty sure we’ve discussed this before: https://trello.com/c/mybEKOFu/281-manual-download-for-unknown-series-shouldn-t-blow-up
Also your pastebin link was private (only you can see it).
I did not even see that. I apologize for that. I will sort out the pastebin issue.
Shedrock
