Navigate between series
First, thanks moderators and other team members for the help getting started. Getting me over some half baked logic, with guidance to make this whole thing finally mesh well within my environment.
There is one thing I miss from another client I used to use, that’s getting from one series to another.
If I’m on a page with “series 1” , I have to navigate back to another series by pressing the “series” icon, select the series I want to navigate to.
I suppose after I get it all done, I won’t have to do this much but it would be nice to navigate from one series to the next with a next/previous navigation button or icon. Like maybe near the scan/rename/search/edit buttons to the right of the series name.
Since I’m still a newbe to ND it might be there somewhere and I have just not found it?
I never understood the need for the previous/next series buttons, found it rare that I’d be on one series and have to go to the next or previous one. You can use the search box at the top to jump to any series: https://db.tt/xtBC1bJG
give it a shot thanks
Firstly this answer is based on my understanding by “Series” you mean “Show” and not “Season”
Yeah i kinda agree with @markus101 although i can see where a next/previous button might be helpful i think the current search box is the better idea that way you can go to a specific show you need instead of blindly clicking until that show comes up
The only reason i probably would use a next/previous button is if i was doing something like running the same function over multiple shows like a rename or re-scan then you could simple hit the function click next then hit the function then click next and so on
how i think (because i might have been the one to request it) that a feature where you can perform a mass edit of several series at once would be the better option if that is the reason you want
here is request link
