Murder in the First Problem
The show Murder in the First is setup to initially download 720p HDTV and then replace with 720p WEB-DL and finally 1080p WEB-DL.
Last month, Sonarr downloaded a behind the scenes file thinking it was the whole season and the download failed. Now, Sonarr no longer downloads the 720p HDTV or 720p WEB-DL. It only downloads the 1080pWEB-DL.
Ultimately, that’s the quality i want but i still want it to download the other releases just in case the 1080p WEB-DL doesn’t get released (happens from time to time withe other series)
How do i get it to forget about that failed download completely and start downloading normally again?
Here’s a screenshot of what i see in the history of EVERY season 2 episode:
Remove the series and re-add it to purge the history.
Which download client are you using?
Thanks. I will do that.
Using NZBGet. I removed the failed download from there.
