Hi all. Sorry if this has been asked before, I did try to look. First let me say I am aware the issue is my own fault and nothing to do with Sonarr setup but I am hoping there is a way to change the video quality of thousands of existing episodes.
I moved from v2 to v3. I did a clean install and then imported my shows. Everything is WEBDL-1080p. After import I setup Sonarr as I wanted. Specifically I set the profile cutoff to WEBDL-1080p.
My problem is that, because I removed quality information when renaming previously, everything was imported as HDTV-1080. So now entire season packs are being downloaded to “upgrade” my HDTV-1080p
If they’re is nothing in the GUI that can do this can i get some SQL commands to do it?
Thanks
