Changing root folder path to all shows doesn’t seem to work:
Series editor, select all, change root folder.
from /path/to/folder/TV/SHOWS/Season X
to /path/to/folder/SHOWS/Season X
Says its updating it but doesn’t actually do it.
Please enable trace logging and provide the logs. https://github.com/NzbDrone/NzbDrone/wiki/Log-Files
Looks like SQLite error? Though it works manually editing each show one by one from its own page.
I went through and did it manually on every single show via its own editor, wow that took some time. Hopefully you can fix this for the future though.
