OS: DSM 7.0.1-42218
Description of issue: Indexers wont communicate, update item in sonar doesn’t work
Not a Sonarr issue.
You need to sync/update Mono’s Certs
Hi, never had this issue before. How do I sync the certs?
Linked you to the synology post on it
Thanks so much it is working again after using the SSH on to the NAS and sudo command in that post you tagged me in, thank you for your help bakerboy446
