Mono version 3.10:
**OSJessica:
**((Debug logs))*http://pastebin.com/VVP66Tud*:
I have ran into the same issue, and I can’t see were the issue is.
I have rebuild my Sonarr Raspberry due to SD Card issue, and I am trying to get this one to work.
I have followed this procedure to install the new Sonarr on a new Raspberry image.
install-sonarr-raspberry-pi-2-latest-stable-mono
I got no errors during the installation
but then I reboot, I see that the mono is not running.
and if I mono /opt/NzbDrone/NzbDrone.exe I get
pi@raspberrypi:~ $ mono /opt/NzbDrone/NzbDrone.exe
[Info] Bootstrap: Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.4645
[Info] MigrationLogger: *** Migrating data source=/home/pi/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Info] MigrationLogger: *** Migrating data source=/home/pi/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Info] NancyBootstrapper: Starting Web Server
[Info] RssSyncService: Starting RSS Sync
[Warn] FetchAndParseRssService: No available indexers. check your configuration.
[Info] DownloadDecisionMaker: No results found
[Info] RssSyncService: RSS Sync Completed. Reports found: 0, Reports grabbed: 0
and I get the loading indicators (bouncing balls)
I have check my mono file location
find / -name mono
/usr/lib/mono
/usr/share/mono-2.0/mono
/usr/share/mono
/usr/share/cli-common/runtimes.d/mono
/usr/share/doc/mono
/usr/bin/mono
/usr/local/etc/mono
/usr/local/lib/mono
/usr/local/share/mono-2.0/mono
/usr/local/bin/mono
/usr/local/include/mono-2.0/mono
and when I ran mono --version I get
Mono JIT compiler version 3.10.0 (mono-3.10.0-branch/ce003f4 Tue Nov 25 20:18:29 UTC 2014)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
TLS: __thread
SIGSEGV: normal
Notifications: epoll
Architecture: armel,vfp+hard
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: sgen
I have rebuild it 3 times, and I get find out why I am not able to get it to auto start.
I look forward to hearing from you.
