Version 2.0.0.5153
Mono Version 4.2.3
My Sonarr monitor status no longer has black and white boxes. Instead there is a white box and some kind of little tick. Does the white box mean its not monitored or is monitored?
Version 2.0.0.5153
Mono Version 4.2.3
That hasn’t changed, not sure what to say other than something in your setup is messed up/missing.
the little tick is actually a tilde. When I goto a series display, for instance, I used to be able to click on the box on the outside of a season to change the monitoring, same with the season pass, no longer.
Its getting very strange. To actually unmonitor I have to click on each episode to get the white box. I am now wondering if I shouldn’t re-install (hopefully that won’t remove all my settings?
