Sonarr version (exact version): 2.0.0.4613
OS: Windows 10 Pro x64
Description of issue: I would like to know if it is possible for Sonarr to monitor the completed downloads folders for titles which have not been downloaded, eg. ripped from DVD or Blu-Ray?
Sonarr doesn’t monitor the folder with Completed Download Handling, it monitors the download client. You’d want to use Manual Import in that case. Drone Factory would also work, but is consider deprecated and is not recommended.
Where would I put the title to manually import?
Manual Import is under Wanted: Missing, from there you can browse to the correct file and import it.
