Seems to me like you’re just putting down my suggestions Markus.
I have a right just like everyone else here to suggest features.
Automation isn’t 100 percent reliable, thats just the way it is. It would be great if it was but it isn’t. I love automation and I use it for certain things like renaming in iFlicks and appending things to filenames with automator, but I do most things manually for a very good reason, iTunes aside I want everything to have the correct metadata and I give everything I download and encode to a friend who keeps it as a full backup in case one of the hard drives fail. I am not the only person in the world who does it this way. People take pride in their media collections.
I’m not about to risk screwing up my 50+TB library by letting Sonarr move and/or rename my files just because I want it to be slightly more functional.
Like don’t get me wrong if you have like 10-50 shows or something and its small enough to have your own backup of it then that is fine, but when you have massive libraries and are monitoring hundreds of shows, you need more options like this.
Not everyone uses Siri yet thats an option, not everyone likes yellow cars but its an option. Life’s about options Markus and everyone does things a little differently.
Sometimes episodes are marked with the wrong episode, or the wrong season, it just happens, and it happens a lot. I can give you shows off the top of my head that sometimes have the wrong season or episode numbers. American Dad!, Bizarre Foods, Bar Rescue, How the Universe Works etc.
I even contribute to the TVDB and TMDB by adding metadata and artwork because I want this ecosystem to thrive and I want everyone to benefit and not just casual users.
And please explain how this would be difficult to implement? All i want is for Sonarr to tell me that the file has downloaded by keeping the cloud symbol or something similar next to the episode instead of removing it and marking it as missing as soon as it downloads. It already speaks to SAB so what is the problem?
Like what about a different symbol that can show an episode has finished downloading? Instead it doesn’t do anything until the file is in the season folder.
And it wouldn’t even effect casual users because they wouldn’t use it, they would use drone factory or completed download handling instead.
I still end up moving the files to the correct location once they are encoded so I don’t mind waiting til then for it to show as done. But I still need for it to show as downloaded for it to be fully functional for me.
And the warning that is always there in settings saying turn on drone factory or completed download handling is annoying, this program relies too much on the thought that every single person is using automation. It’s just not true. And I read the article that said turn on and off completed download handling to remove the warning and it did but it showed up again a while later.
Look, I’ve said before, the program is awesome and other than the 2 issues that I have with it I really can’t fault it, its way better than Sickrage, its reliable, its simple to use and has a beautiful and elegant GUI yet its packed with advanced features all I am trying to do is help improve it for people like me who don’t want to use full automation or who have their own ways of doing things.
I just want to contribute or help make this program all it can be by giving you the insight from someone who uses the program daily and has been for years, I hope you understand that.
