Mobile login that allows for Autofill
[On iOS] It’s great how the Couch Potato login page is such that the user name and password are fields on the page, that way AutoFill can enter your credentials for you. Like SickBeard did, Sonarr has a popup window appear when you go to the WWW on an iPhone and you have to enter usr/pwd each and every time you go to the page.
Would be great if the login is fields on the page which can be stored and later Autofilled.
Thanks!
Already on Trello, but its no a priority for us: https://trello.com/c/10E1a3Tf/698-login-page-instead-of-prompt
Any different on Chrome for iOS? Works as-is in Chrome on Android.
Chrome on IOS doesn’t store usr/pswd unfortunately.
