Missing downloads - Sonarr not working as intended
Mono version (if Sonarr is not running on Windows): 4.6.2-0096
OS: DSM (reached via MacOS)
Debug logs: sonarr.debug.txt
Description of issue: I’ve just started using Sonarr on my Synology 918+. As Indexers I’ve added FastNZB and Rarbg. As download clients, I’ve added DownloadStation and SABnzbd. I’ve added several series, but the vast majority of them aren’t downloading. It has successfully downloaded 44/125 episodes of Parks And Recreation, and 14/33 of The Handmaid’s Tale, but all other episodes and shows are not downloaded.
Activity gives a notification bubble of 246 with dozens of episodes under Queue, History, and Blacklist, but nothing’s happening. Under Wanted, also a ton of episodes are listed.
SABnzbd and DownloadStatiion both don’t show anything in their queue.
I have the same issue with Radarr by the way, I imagine I’ve made a similar mistake there. Any and all help is much appreciated.
I might have figured it out, or at least something that was amiss. I hadn’t set up a Torrent download client since I overlooked that that needed to be done separately. I thought setting up DownloadStation for NZBs automatically set it up for torrents as well. It’s downloading something now, eager to see how the handling is done when the files are completely downloaded.
