I wanted to ask if it is possible to add the metadata settings for boxee box.
It has .tbn files for serie episode images. This is not yet possible with one of the current metadata settings.
Pretty sure it just uses XBMC/Kodi metadata, but may be expecting the legacy XBMC metadata.
Is there information on exactly what it requires somewhere?
The folder structure they give on BoxeeHacks Boxee custom art is.
TVShows
± [TVShowName]
± tvshow.nfo
± Season 1
| ± [TVShowName] 1x01 - [Title].mkv
| ± [TVShowName] 1x01 - [Title].tbn
| ± [TVShowName] 1x01 - [Title].nfo
This is the same on boxee support " http “support.boxee.tv/entries/20665568-Custom-Cover-Art-for-Media-Library”
For nfo creation creating nfo file
This is something I would also like.
Until there’s a better all in one box solution on the market, the boxee box still rules
Me too!
BTW - for TV shows, I use Plexee on the Boxee Box, and it MOSTLY works well with XBMC metadata…
I also believe that it’s the best for my usage today. Waiting for a similar all in one solution that has wired gigabit Ethernet - maybe then I’ll switch…
Jon
Looks like its legacy XBMC metadata it supports, added to Trello: https://trello.com/c/ucAtL0ZW/921-legacy-xbmc-metadata
