Sorry if this has been asked but does this program download the meta meta data to go along with such programs as media browser?
We haven’t implemented metadata in v2, but its on the todo list (on Trello), The one specifically for media browser is here: https://trello.com/c/poCk50Nd/234-mediabrowser-metadata-support - it could use a lot more details in order to get it right, it would be great if you could update it.
what do i need to do to update or what do I need to add?
Theres just a link there now, so anything that would be useful for implementation, what files need to be created and what do they do, links to XML formats for series and episode.
A good example is the XBMC metadata card: https://trello.com/c/Su2ZyWTp/225-xbmc-metadata
Metadata creation, even of just the series.xml file for a new TV show (which MediaBrowser3 needs to identify it as a TV show), would be awesome.
When I add a new TV show to Drone, the series.xml file isn’t created, so I have to start up SickBeard to add the new show, then shut it down.
If there is an easier way of doing this, without having to create the file manually, I’d appreciate an answer.
Thanks.
Drone doesn’t yet support MB3 metadata, until it does I don’t see another way of doing this.
OK, thanks markus.
Is there any sort of timeline for metadata support etc. please ??
Its not something we’re currently looking at and we’re not ones to give estimates/set deadlines for ourselves.
OK, thanks.
I see MediaBrowser3 series.xml file is now being created when a new show has been added in the dev build - many thanks.
