Version
2.0.0.5252
Mono Version
5.4.1.6
Synology Docker
So long story short, my directories were off, so every that was downloaded is sitting in /downloads. the torrent is no longer active so sonarr doesn’t see them to import. When I do a manual import for that folder I can see 50+ items downloaded but not imported. When I choose /downloads to import it scans/searches for a min then says
Unable to load files for manual import. Check logs for more details.
When i check the logs this is what it says
Invalid season detected during sample check: Expected one season, but found 2 (2016, 2017)
NzbDrone.Core.Parser.InvalidSeasonException: Expected one season, but found 2 (2016, 2017)
at NzbDrone.Core.Parser.Model.LocalEpisode.get_SeasonNumber () [0x0007e] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Parser\Model\LocalEpisode.cs:46
at NzbDrone.Core.Parser.Model.LocalEpisode.get_IsSpecial () [0x00000] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Parser\Model\LocalEpisode.cs:50
at NzbDrone.Core.MediaFiles.EpisodeImport.Specifications.NotSampleSpecification.IsSatisfiedBy (NzbDrone.Core.Parser.Model.LocalEpisode localEpisode, NzbDrone.Core.Download.DownloadClientItem downloadClientItem) [0x0001f] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeImport\Specifications\NotSampleSpecification.cs:32
Any ideas?
Edit: in this instance since they are all in folders would enabling the drone folder be easier?
