Hey,
I’m new to Sonarr, as of today.
I have a peculiar setup when it comes to sorting my shows.
My TV shows are sorted in to folders based on the following criteria
Quality/Showname/Season.
So my folders typically look like this.
…\TV-1080p\Arrow\Season 04\Arrow.S04E01.1080p.HDTV.X264-DIMENSION.mkv
…\TV-720p\Arrow\Season 04\Arrow.S04E08.720p.HDTV.X264-DIMENSION.mkv
…\TV-DVDRiP\Full House\Season 04\Full.House.S04E01.Greek.Week.DVDRip.XviD-SAiNTS.avi
with one exception being anime
…\TV-ANiME\Avengers Assemble\Season 02\avengers.assemble.s02e25.new.frontier.720p.hdtv.x264-w4f.mkv
…\TV-JP-ANiME\Durarara!!\Season 02\Durarara!! - S02E19 - [044] - [1080p].mkv
Now, I see that Sonarr is able to sort based on Series name and Season under the Root Folder for the show.
For ny japanese Anime that is fine. I can just specify …\TV-JP-ANiME as the root folder, and I dont care what quality goes there. The higher the better of course.
For my TV-Shows however, I would like to sort them based on quality.
Now, I’ve used FileBot for renaming shows, and it supports some nifty features.
For instance, my naming format for TV-Shows is set as
…\TV-{hpi}\ {n}\Season {s.pad(2)}\ {n} - {s00e00} - {t}
and for anime its
…\TV-JP-ANiME\ {n}\Season {s.pad(2)}\ {n} - {s00e00} - [{absolute.pad(3)}] - [{hpi}]
{n} = showname
{s} = season (.pad(2) specifies that I want season numbers padded to 2 numbers)
{hpi} = resolution eg: 1080p
{absolute} = Absolute release number
In this case {hpi} sets the quality based on resolution. It doesnt do HDTV-1080p, but straight 1080p which I prefer.
So based on that it can look at the show and put it in the correct quality folder based on actual resolution in the file.
Is there any way for me to set up Sonarr to sort based on quality?
(and as a secondary question slightly off topic: Can I get it to rename quality with resolution only?)
If it isnt, I’ll just have to have Sonarr do all the downloading to a secondary folder, and do rename and move from there manually.
